New build thread from Arrowmntdiesel 87 4x4
News, rants, and raves.
Re: New build thread from Arrowmntdiesel 87 4x4
Postby Halden » Sat Mar 12, 2016 7:13 pm
Wow Mark. I remember when i did front end work on my truck it was a pain sitting on the cold garage floor... Thats a real nice set up!
tdipup
Isuzu vehicle(s): Diesel P'up
Postby tdipup » Sat Mar 12, 2016 7:39 pm
It's looking great! Maybe I'll come check it out over spring break!
1983 P'up 4X4 Diesel Brown 4 speed
2002 Volkswagen Jetta TDI Diesel Black 5 speed
2013 Subaru Outback Limited Green CVT (Wife's car)
1967 Mercury Monterey 2 door fastback 390 V8 white (My 1st car ... I still own it!)
arrowmntdiesel
Postby arrowmntdiesel » Sat Mar 12, 2016 9:04 pm
Isuzu Faster wrote:Mark, some really interesting work! Quick question: Was removing the dashboard out of the truck a relatively easy process? It seems like you've done this multiple times - with multiple cracks in my own dashboard, it makes me wonder if trying to remove the dash to patch those cracks would simply make the situation worse.
Steve,
There are 10 fasteners too the dash component, some wires and ducting. It's not bad to remove and once out and on the bench, the dash pad itself will come off the hard plastic shell. The hardest bolts to remove may actually seem like the easiest. These would be the 4 phillips head, machine screws that are at both sides of the dash that are facing down towards the floor board. Why are these difficult you ask.....they thread up into a flat bracket that has a turned up edge on it that holds moisture and those little guys just don't want to break loose very easy at all. Use penetrating oil first and make sure you have the right sized screw driver. You're first attempt needs to be with a good grip on the bolt head and with a lot of upward pressure so that the screwdriver does not slip in the bolt head. There are screws behind the outer air vents as well and one under the steering column as well.
tdipup wrote:It's looking great! Maybe I'll come check it out over spring break!
Love to see you Chuck! I will continue to update on progress as it happens. Next I will tackle the rear axle and the back half of the chassis.
Thanks to all.
Mark
AAS degree Diesel Technology 2014, 10 yrs Isuzu Pup diesels. Owner: Arrow-Mountain Diesel services & Arrow-Mnt Windows, Medford, OR. Love God! One Marriage-One Wife, 2 awesome young ladies as my kids. Happily Married for 25+ years. One Blessed Man!
Crabshackint
Isuzu vehicle(s): 82 pup diesel 2wd no ps no ac
Postby Crabshackint » Mon Mar 14, 2016 10:33 am
Awesome job Mark, this is a great project. Thanks for posting updates.
-Kyle-
1982 diesel 2.2 pup longbed 2wd 5 spd no PS no AC.
1988 2.3 ranger 2wd 5 spd
2004 Toyota Tacoma inline 4 5spd 4x4
arrowmntdiesel
Postby arrowmntdiesel » Tue Mar 29, 2016 8:25 am
Small change of direction here on the project. It was time to work up on the bench now. :D I have had a run of transmission replacements, the most recent from the local Oil Stop drive through. There guys installed gear lube in the transmission and it had begun to make noise. The owner of the truck directed them to me and I didn't have an overhauled transmission ready to go. Also the white truck I just hauled back from Wa. with Uncle Donnie needs a transmission, so ...... It's time to overhaul some trannys! I did the two 2wd already, these pictures are of the 5 speed 4wd on Chucks truck and the other MSG-5 4wd is for Tracy (Luvcamas).
Getting it disassembled I find a surprise... Notice the front countershaft gear
Here is a closer look at it
With the tooth being broken on the lower countershaft, that piece is a cast and machined component that includes all the other gears on the countershaft. It is not singularly replaceable. That means that if I don't have the exact matching countershaft to replace it with, then all the mates on the main shaft need to be replaced with it as well. (Which is what I ended up doing) Isuzu ended up using several different pitches and teeth count on the gears and the casting on the countershaft (rings) are an indicator of which gears they are.
I was keeping track of original paint daubs with my camera
Gears, bearings, seals and gaskets are all replaced and now the reassembly begins
Finally back together and right behind the assembled tranny is Tracy's tranny coming apart
The infamous bearing retainer plate that is diesel specific and the diesel bell. This Bell came from David Wallace that I picked up several years ago at the NW Pup meet in Rainer
Kept track of the paint markings just for the fun of it.
I'll keep moving ahead on it slowly and as always keep the board posted of progress. The Oil Stop truck comes in this week for a tranny swap.
Mark
tdipup
Postby tdipup » Tue Mar 29, 2016 11:17 pm
Most impressive, Mark! When this machine is finished, it may just take the Volkswagen's place in the garage! I'm essentially going to have a NEW little 4WD diesel truck! It's too bad some unfortunate circumstances kept me from making it over during spring break ... maybe I'll take a personal day in mid to late April.
Beesboer
Postby Beesboer » Tue Dec 06, 2016 4:16 am
Excellent job Mark! Why has the thread gone quiet?
Henk
'84 C190 P'up (so far engine only!) Sold
'89 C223 Pickup 4x4 Project
'04 Isuzu KB 300 4x4 D/C Sold
'10 Isuzu KB 300 Dteq LX 4x4 Spacecab
arrowmntdiesel
Postby arrowmntdiesel » Wed Dec 07, 2016 8:26 pm
Beesboer wrote:Excellent job Mark! Why has the thread gone quiet?
I'm patiently waiting for "windows" part of Arrow-Mountain to give me a break so I can attend to the "Diesel" side of Arrow-Mountain. :D
It has been a very busy year for windows... but..I did just wash the frame off and get ready for finishing the chassis up after the 1st.
Stay tuned.
Mark
Beesboer
Postby Beesboer » Thu Dec 08, 2016 12:27 pm
Looking forward! I'm busy with a project of my own, an '88 Pickup 4x4 C223. I envy you guys in the U.S. OEM parts seem quite easy to come by. I spent an hour with the parts guy at G.M. today for lower control arm bushes and fulcrum bolts, only to hear I may have them by next Tuesday...
Henk
Postby JoeIsuzu » Mon Jan 16, 2017 11:21 am
Mark, it was great talking with you Saturday. I'm just putting the forum on notice that I'm reserving a place in line for a project. I won't share any more details yet, other than that 1) it won't start until Chuck's truck is done, 2) Mark's family and glass business take priority, and 3) it involves the C223-T that's currently sitting in my garage--hopefully, with upgraded rods and a modern turbo. ;)
Completion will no doubt be quite a while off--but I'm "officially" in the line!
Postby Halden » Tue Jan 17, 2017 11:39 pm
JoeIsuzu wrote:modern turbo. ;)
It would be interesting to pair a VGT with a C223... sadly you need some sensors and a control module for that. Be really great to have a VGT brake for it too!
arrowmntdiesel
Postby arrowmntdiesel » Wed Jan 18, 2017 8:51 am
JoeIsuzu wrote:Mark, it was great talking with you Saturday
Jack,
Likewise, It's always good to catch up with you and talk family. My how our kids grow up so quickly.
This truck project of Chucks is about to reappear hear in this build thread with the rear axle getting finished and the engine and transmission getting set in the frame. So stay tuned.
Mark
