Injection Pump leaking fuel
Re: Injection Pump leaking fuel
Postby JoeIsuzu » Mon Oct 16, 2017 2:35 pm
SpaceCab, or long bed?
crazy4diesel
Isuzu vehicle(s): 1986 Pup Turbo Diesel, DLX, manual, long bed / 1983 M-B 300TD with manual transmission / 1991 Mazda Bongo 2.0TD / 2012 VW Jetta Sportwagon manual
Postby crazy4diesel » Mon Oct 16, 2017 3:15 pm
It's a long bed.
So many diesels, so little time.
crazy4diesel
Postby crazy4diesel » Mon Oct 16, 2017 4:34 pm
Also Jack, the picture in your avatar is the EXACT truck I owned back in 1984. LS long bed with the Red and Silver! It was a 5-speed, and I sure put a lot of miles on that truck.
jamezg
Isuzu vehicle(s): 86 2.3 longbed gasser, 86 2.2 turbo spacecab, 87 NA longbed
Postby jamezg » Mon Oct 16, 2017 5:03 pm
Get it or i will.
5K is within my price range.
Will give you a a few days.
jamez
74 610 PU dump truck
77 dodge custom fire van.
80/82 VW caddy Diesel
84 Sabru brat -broken
84 Toyota motorhome converted to flatbed
86 Isuzu P'up TD spacecab
86 Isuzu p'up 2.3L longbed
87 Isuzu P'up NA longbed
Forklift,excavator,tractor,motorcycles
crazy4diesel
Postby crazy4diesel » Thu Oct 19, 2017 11:58 am
I'm getting the truck, and Paul's shop will look at the pump. Crossing my fingers that all will be good! Thank you everyone, and I'll be posting in the intro with pics of the new truck.
crazy4diesel
Postby crazy4diesel » Sat Jun 15, 2019 4:24 pm
It's hard to believe it's been so long, but I made the move to the Seattle area, and drove the truck up from Southern CA, and it did great. Sadly, it's sat, because there was a nasty oil leak I needed to chase down, and I ended up totally remodeling the house I bought, doing all the work myself, which meant all vehicle stuff went on the back burner.
But, enough of that...I found the oil leak it was just the return line from the turbo, it was basically just hanging there.
But, back to this topic of this thread, there is a a new fuel leak but this one is easy to see, it's clearly coming from the fuel return banjo. Both return lines were cracked, so I replaced them and the clamps, and that slowed the leak considerably, but did not eliminate it. Any ideas on where it's coming from and how to fix? It is the one above the fuel cut-off, with the bleed screw in the middle of it, what ever that's for.
