Rebuild time
robgt22
Rebuild time
Postby robgt22 » Thu Jul 09, 2015 8:38 pm
OK so I checked compressions on my c223 and it's time for a rebuild :( :( Also there is a lot of sludge inside the engine, which probably was before I bought it. I'll keep you updated and post some photos when the rebuild starts
95 passport with a c223, bolted to a gasser mua5. Garrett gt1749, 15 psi of boost. Straighpiped and intercooled. 2.5” suspension lift and 1.5” body lift, ball joint flip, 1 1/2” diff drop. 33x12.5 R15 tires, 12000 pound winch.
01 Trooper with a 4jg2 swap
robgt22
Re: Rebuild time
Postby robgt22 » Wed Jul 29, 2015 5:28 pm
So finally I opened the engine and here's what I found
OzarkDaredevil
Re: Rebuild time
Postby OzarkDaredevil » Wed Jul 29, 2015 6:10 pm
Looks like you caught it just in time.
robgt22
Re: Rebuild time
Postby robgt22 » Tue Sep 15, 2015 7:15 pm
Pictures of the rebuild so far
OzarkDaredevil
Re: Rebuild time
Postby OzarkDaredevil » Tue Sep 15, 2015 8:09 pm
That's a lot prettier!
joeshmoe44883
Re: Rebuild time
Postby joeshmoe44883 » Tue Sep 15, 2015 8:30 pm
Did you sleeve the block?
robgt22
Re: Rebuild time
Postby robgt22 » Tue Sep 15, 2015 9:49 pm
Yeah, it definitely looks a lot better, hope it runs better too :D. Yes, I did sleeve the block
Re: Rebuild time
Postby JoeIsuzu » Tue Sep 15, 2015 10:11 pm
robgt22 wrote:Yeah, it definitely looks a lot better, hope it runs better too :D. Yes, I did sleeve the block
Hope you'll tell us more about that. Ronster had one done, and I think his mechanic had quite a hard time getting the sleeves in correctly.
robgt22
Re: Rebuild time
Postby robgt22 » Wed Sep 16, 2015 10:18 pm
Well, the sleeve part was the only thing that my mechanic didn't make. I took the block to an engine rebuild company just to get the sleeves in, as it was the hardest part.
ghostridin'theP'up
Isuzu vehicle(s): 1982 P'up diesel 5 speed short bed; 1986 P'up turbo diesel 5 speed long bed
Re: Rebuild time
Postby ghostridin'theP'up » Sat Sep 19, 2015 12:03 pm
Looks great! Curious, do you know how many miles were on the motor before the rebuild?
86 pup - turbo diesel
82 pup - diesel 5 speed base model
53 gmc - no rust project
robgt22
Re: Rebuild time
Postby robgt22 » Sun Sep 20, 2015 2:14 am
The engine had around 325,000 miles, but previous owner didn't take good care of it. Had it running without air filter for a long time, until I got it
robgt22
Re: Rebuild time
Postby robgt22 » Fri Oct 16, 2015 12:46 pm
Just installed the engine. Everything that's missing is adjusting valves and adding oil. Will fire her today. :D :D
OzarkDaredevil
Re: Rebuild time
Postby OzarkDaredevil » Fri Oct 16, 2015 2:37 pm
Let us know how the maiden voyage goes. BTW love the squeeky clean engine bay.
Re: Rebuild time
Postby Halden » Fri Oct 16, 2015 7:20 pm
robgt22 wrote:Just installed the engine. Everything that's missing is adjusting valves and adding oil. Will fire her today. :D :D
Don't forget the return lines on the injectors!
83 LS Long Bed Diesel
robgt22
Re: Rebuild time
Postby robgt22 » Sat Oct 17, 2015 11:42 am
Thanks! I installed them, adjusted valves and added oil but couldn't start it. The oil line that goes into the vacuum pump gave up :/.
