Page 1 of 1
AC belt interfers with lower radiator hose
Posted: Sun Jun 01, 2014 6:52 pm
by reidspup
My AC belt rubs against my lower radiator hose unless I tie it back with some string or wire. On rock auto it shows lower radiator hoses for trucks with out AC and none for trucks with AC. I am not sure there is a difference. It seems like a stupid question but why can't I fit the hose and belt without interference? My AC doesn't work, I don't need it where I live, and it makes working on the engine much more difficult so I might just remove it anyway. I would be interested in the pulley which replaces the AC unit if anyone has it. Thanks Reid
Re: AC belt interfers with lower radiator hose
Posted: Tue Jun 03, 2014 9:18 am
by Halden
On your timing cover there should be a little hose clamp/bracket to pull the hose back.
Posted: Tue Jun 03, 2014 11:37 pm
by arrowmntdiesel
Reid
If it is an aftermarket lower radiator hose, then most likely it is for a non AC truck and is formed a bit different. The only place I have been successful locating the proper hose is from our faithful friend JLemond. Napa part #7777 is the hose the book calls for and it will not work on an AC truck, or for that matter a truck with the PS idler pulley either.
Mark
Posted: Sat Jun 07, 2014 9:09 am
by reidspup
Slow response on my part. Thanks for the tips.
Posted: Sat Jun 07, 2014 7:02 pm
by OzarkDaredevil
I ran a generic accordion type hose on mine. Looks crappy but works fine.
