Questions -- Front Crank Seal
- paperstreet
Howdy!
Mid belt / head / water pump replacement right now, and I'm thinking it would be a great idea to pull the Crank pulley bolt off and replace the front crank seal (as it's both leaking AND included in the timing belt replacement 'kit')
I have a few questions for y'all:
Q: Is the bolt reverse thread? My guess is yes, but I'd love to hear your thoughts...
Q: Any thoughts on removing it without an impact wrench (My 1/2" drive impact is at work and my truck is at home, and my home compressor doesn't have the grunt to turn my impact).
Thanks!
Frank
Thanks!
Frank
1985 Isuzu P'up diesel 5 spd (gasser trans) running B99
- puttputtinpup
Re: Questions -- Front Crank Seal
there are 4 small bolts that hold the crank pulley to a hub which fits onto the end of the crank w/ the large bolt. I know that when changing the timing belt that the pulley only needs to come off. Now, I'm can't tell you if the hub has to come off to replace the seal. Someone else might want to chime in here.
Currently P'up-less, but keeping my eyes open for a good deal
Click this link for misc. diesel technical bulletins & other info
- arrowmntdiesel
Yes, The hub will need to come off of the crank snout to replace the front crank seal. I also know that the front main cap is exposed and not under the oil pan. This could make it a bit easier to replace the front seal. As far as removing the crank bolt.....That may be a bit difficult without a impact driver. Trying to think of a way to stop the engine from turning over while breaking it loose???? The treads are right hand threads. Righty-tighty, Lefty-loosey!
Mark
Mark
AAS degree Diesel Technology 2014, 10 yrs Isuzu Pup diesels. Owner: Arrow-Mountain Diesel services & Arrow-Mnt Windows, Medford, OR. Love God! One Marriage-One Wife, 2 awesome young ladies as my kids. Happily Married for 25+ years. One Blessed Man!
- paperstreet
Thanks, guys! 'Right hand threads' is a good tip.
I'm making a steel plate to bolt onto the crank snout, and welding a bar to the plate for leverage.
If I can upload a picture when it's done, I'll share...in fact, if anyone else gets in this situation and needs to borrow it, just pay for the shipping! I'm happy to spread the help.
Thanks, and I'll keep you posted.
Frank
Frank
- paperstreet
Ok...it's crude, but it did the job just fine. Maybe it was all the build up to it, but the bolt wasn't nearly the Leviathon I was expecting. It was tight, sure, but not a life changer.
Now...if I can only figure out how to post a picture of this special P'up tool...
http://dl.dropbox.com/u/23041538/Crank%20Tool.JPG
http://dl.dropbox.com/u/23041538/Crank% ... handle.JPG
Seriously, it would be great if I could just post these here instead of links.
In any case, it worked like a charm, and I'm happy to lend it after the job is done (you pay shipping to and from). I know the second time around, I'll be a little more accurate with my hole placement (I was in a hurry)
{{Handle sold separately}}
Frank
Frank
- paperstreet
Handle is a solid, stainless 16mm rod that fit telescopically into the 16mm ID, 21.5mm OD tubing. A long 5/8" drill bit honed it out just fine.
paperstreet wrote:Seriously, it would be great if I could just post these here instead of links.
I see you figured that out (next post). I've limited the size of "remote" images because if they're too large, they make whole page wide. It's better to upload them here, and the forum will display them in a size that fits the page. People who want to see the large version can click it and it will enlarge.
See "Can I post images?" in the FAQ section.
The easyest way to remove the crank bolt. Yout need a 24 size tool like this : http://tomnerszerszam.hu/shop_ordered/5 ... 07620L.jpg
Take the tool with fix rod to the crankshaft bolt, and rotate to the point where the tool and the frame meet. Then you turn the igniton key on to only a half second. Your starter motor will loosen the bolt...
1993 Isuzu Pickup
2,5 D (4Ja1) Reg. cab, long bed.
A/C, without P/S,
2WD
A/C, without P/S,
2WD
- paperstreet
Papik wrote:The easyest way to remove the crank bolt. Yout need a 24 size tool like this : http://tomnerszerszam.hu/shop_ordered/5 ... 07620L.jpg
I've heard tell of such daredevil feats...I considered it...I really considered it!
Then I calmed down and welded a tool together (see above).
Thanks for the tip, though!
Frank
And Jack, thanks for the tech info on pics.
I always use the starter and a long breaker bar to loosen crank bolts. You just have to remember to do that first, before you take the timing belt off.
1984 Pup MPG "Big Red", CSD delete
1990 Trooper 2.6l on 33's w/ black 'yota rims
1993 Chevy K2500 6.5l TD service body.
I would not recommend trying to take off the front main cap to replace the front main seal. It's unnecessary and you'll break the seal between it and the timing plate. Just get off the crankshaft timing belt cog, check the surface of it which rides against the front main seal for a groove - if it's grooved you'll need a new one or speedi sleeve. With that out you'll see a thin plate held in by three M6 hex cap screws. Remove those and use a pick to yank the old seal out. The front main seal seals against the timing belt cog so there's lots of room to grab it and pull it out unlike the rear main which seals against the crankshaft.
- paperstreet
Thanks, guys
The front cog was grooved...but I'm desperate to have this truck running, so I put the new seal in with some grease and I'm gonna have to live with it.
I'm gonna search the forums about torquing the injectors down. I assume i need to buy a 30mm crow's foot to do it. I'll search, and if I don't find anything, I'll start another thread about it...
Thanks,
Frank
Thanks,
Frank
arrowmntdiesel wrote:Yes, The hub will need to come off of the crank snout to replace the front crank seal. I also know that the front main cap is exposed and not under the oil pan. This could make it a bit easier to replace the front seal. As far as removing the crank bolt.....That may be a bit difficult without a impact driver. Trying to think of a way to stop the engine from turning over while breaking it loose???? The treads are right hand threads. Righty-tighty, Lefty-loosey!
Mark
My bolt is loose already.
I have a question how to tight this big bolt and what is the torque spec.
Thank you
Tad
I always snug the bolt in with air wrench, then take the breaker bar and turn clockwise till you feel some compression build. I have a piece of solid shaft i place down onto the end of the breaker bar with its tip just above 3oclock position and a few whacks with a 6lb hammer will take up anymore clamping of the belt hub.
I also use the breaker bar against the frame and bump the starter... dont try that with a cheap-0 bar though. Works on my monteros also.
86 Trooper TD
