throttle cable stuck in cold
danorte
Postby danorte » Tue Feb 15, 2011 9:54 am
My 1987 T diesel space cab is not a daily driver in the snow. However during the cold last weekend it started fine but I was unable to push down the accelerator pedal. After a few minutes of warm up it worked just fine. Anyone had the cable freeze. ? can it be lubed, which end is easiest to access to lube? Thanks again. North
North, 1987 space cab turbo diesel 5 spd with 332000 mi.
Re: throttle cable stuck in cold
Postby JoeIsuzu » Tue Feb 15, 2011 10:15 am
I can't see how it would freeze unless it got moisture inside. Or, I guess ice on the injection pump could block throttle (not really a throttle, you know what I mean) from moving.
danorte
Postby danorte » Tue Feb 15, 2011 11:02 am
Durn, Pump works fine by manual method. Only throttle cable is stuck. But after just a few minutes warm up it is fine. Has anyone replaced this cable. If so is it just easy disconnect. My try to lube it this weekend. North
Postby JoeIsuzu » Tue Feb 15, 2011 11:06 am
Mine broke a couple of years ago. It was easy to replace. JLEMOND usually has them in stock.
Gerald K4NHN
Postby Gerald K4NHN » Tue Feb 15, 2011 1:52 pm
Larry just replaced his and said that it was about a 20 min job..
Gerald K4NHN
Cayce, SC
"One test is worth a thousand opinions"
1983 LS DIESEL LONG BED 2 W/D 126K miles
1986 LS Trooper Tubro Diesel 4 W/D 186K + miles SOLD
kravdraa
Postby kravdraa » Wed Feb 16, 2011 6:56 am
Buy a back up now from Jerry while you can. Remove the old and keep it as a spare.
81 Long bed PuP 2.2 Diesel
Using Bio-D
quicknotslow
Postby quicknotslow » Thu Feb 17, 2011 9:09 pm
Check the bends if there real sharp, (at firewall in My case) it could be frayed at the bend. Mine has been hard to push for a long time. The frayed cable was why the throttle stuck open. Just take the cable off and try pulling it on both ends. Good Luck
Larry
1982 LONG BED DIESEL
1986 TURBO SPACE CAB With 59034 Miles
danorte
Postby danorte » Mon Mar 07, 2011 10:24 am
new cable installed, yes 30 min or less. Looking at old cable still a mystery. Nothing frayed, nothing rusted. New cable does not look like old cable at throttle pedal end, however fit is perfect with no modification. Looks like they just cleaned it up and made it more simple. North
