Exhaust/intake manifold studs
newpup
Isuzu vehicle(s): 1986 SpaceCab Pu'p gaser converted to diesel with 1981 C223, 1986 Trooper diesel with 3rd gen. rods
Postby newpup » Sat Aug 07, 2010 3:10 pm
I'm putting the head back on an '86 Trooper turbo diesel (C223T). Unfortunately, I didn't take it off and have some questions:
There are 9 threaded holes for the intake/exhaust manifold. How many are studs and how many bolts? Where do the studs go verses the bolts?
When I put the timing belt back on, I know the arrows on the pump and cam gears must lineup while the notch on the balancer pointing to 0 TDC. Question is, how do I know if I'm at TDC on the compression stroke or the exhaust stroke or does it matter? Don't I need to know this to adjust the valve clearance?
Thanks
JLEMOND
Re: Exhaust/intake manifold studs
Postby JLEMOND » Sat Aug 07, 2010 8:48 pm
newpup wrote:I'm putting the head back on an '86 Trooper turbo diesel (C223T). Unfortunately, I didn't take it off and have some questions:
Thanks
WHEN YOU HAVE THE CAM AND PUMP PULLEYS AND THE CRANK PULLEY AT THEIR CORRECT MARKS, YOU WILL BE ON TDC NO 1 CYL AND BOTH VLV SHOULD BE LOOSE
wylie's pup
Postby wylie's pup » Sat Aug 07, 2010 9:59 pm
Check out these threads;
viewtopic.php?f=1&t=1263&p=7462&hilit=timing+belt#p7462
viewtopic.php?f=36&t=2614
They're about timing belt installs, but would help with the TDC question too. They're both from Jerry, very good. If I had a turbo I'd try to help with the bolts and stud question.
Brian
(sorry you'll have to copy and paste the links, got them from another thread and for some reason they're not live)
1983 P'up Diesel 4x4 long bed 4 speed w/ air 211500 miles
StevePT
Postby StevePT » Sun Aug 08, 2010 1:00 am
Seven of the hole should be studs. Loosely fit the intake manifold up to the head and you'll see where two bolts go through the intake manifold that have to be about 4" long. These ones need to be bolts and the rest are studs.
Image Image
Users browsing this forum: No registered users and 4 guests
