c223t flywheel
teener
Isuzu vehicle(s): 82 Chevy LUV Long Bed Diesel
c223t flywheel
Postby teener » Fri May 22, 2020 5:25 pm
Hey all,
I'm trying to identify a flywheel for sale on ebay. Does anyone have pictures or part numbers of a real deal c223t flywheel I can use as a reference? The one pictured does not have a hole for the crank dowel which has me perplexed.
Thanks
Re: c223t flywheel
Postby Red Truck » Fri May 22, 2020 6:33 pm
May not be exactly what you're looking for, but I just did a search on this forum for "c223 flywheel" and saw quite a few pics of them labeled as such; there's probably a part # floating around in the dialogues as well. Seemed to be an issue about 6 or 8 bolt holes, etc..../regards
'87 Isuzu p'up 2.3 gas, 5spd, 4WD, base model, Fed spec
bobbyr
Re: c223t flywheel
Postby bobbyr » Sun May 24, 2020 4:27 pm
The one on the left is for na engine the one on the right is for a turbo engine
teener
Re: c223t flywheel
Postby teener » Sun May 24, 2020 6:20 pm
Thanks guys. I was able to find some pics and the side by side is helpful.
I think the one on eBay it is actually a first gen gasser luv flywheel that is mislabeled. It is thin like a turbo flywheel but has no hole for a dowel pin.
clutches and flywheels.JPG (67.68 KiB) Viewed 74 times
