Isuzu c223T accelerating problem
Adiddas11
Isuzu vehicle(s): 81 chevy luv 4x4 diesel/ 81 chevy luv diesel 2wd/85 chevy s10 diesel(now converting to TD) /1994 isuzu pickup 2.3
Postby Adiddas11 » Mon Apr 16, 2018 6:45 pm
I put a isuzu c223T in to my dads s10 and my problem is that when you press on the throttle and then let go it accelerates and doesn't stop untill i shut the car off.
Pupfocused
Re: Isuzu c223T accelerating problem
Postby Pupfocused » Tue Apr 17, 2018 10:45 am
My guess is that it one of three things. 1) the throttle cable is sticking 2) problem with the turbo and engine oil is going into the intake 3) problem with the pump
Jim
1981 diesel pup(gone)
1985 4x4 diesel pup
1986 diesel trooper
Adiddas11
Postby Adiddas11 » Tue Apr 17, 2018 3:24 pm
I what way can the pump be bad, i just got mine rebuilt
Postby JoeIsuzu » Tue Apr 17, 2018 4:15 pm
Adiddas11 wrote:I what way can the pump be bad, i just got mine rebuilt
I can't answer that one, but who rebuilt it?
I'd always suggest ruling out the easy stuff first. That's why Jim put 1 & 2 before 3: ;)
Pupfocused wrote:1) the throttle cable is sticking 2) problem with the turbo and engine oil is going into the intake
Adiddas11
Postby Adiddas11 » Tue Apr 17, 2018 5:08 pm
Turbo auto and diesel rebuilt the fuel pump
Postby JoeIsuzu » Tue Apr 17, 2018 5:15 pm
Adiddas11 wrote:Turbo auto and diesel rebuilt the fuel pump
I'd try to rule out the other possibilities. Then, if convinced it's the pump, I'd contact the people who overhauled it.
Postby puttputtinpup » Tue Apr 17, 2018 6:09 pm
How about running a string concentration of Seafoam through the system 1st to help dissolve gummed up parts inside the injection pump. The CSD piston may be sticking also inside the housing preventing timing to go to normal until more rpm/pump pressure drives it back into place and timing not advanced.
Adiddas11
Postby Adiddas11 » Tue May 08, 2018 10:18 am
The CSD was replace according to the company with one that was ordered from Japan
downunderyank
Isuzu vehicle(s): spacecab diesel Holden rodeo 1993, 1986 pup spacecab, 1987 pup spacecab
Contact:
Postby downunderyank » Thu May 31, 2018 5:58 am
Take the throttle cable off the pump and see if it moves freely in its sleeve? I had one that was gummed up and it did this.
converted '86 diesel spacecab
kravdraa
Postby kravdraa » Thu May 31, 2018 12:56 pm
You have a gross symptom. The solution is probably simple as already mentioned with a possible sticking cable.
81 Long bed PuP 2.2 Diesel
Using Bio-D
Postby JoeIsuzu » Fri Jun 01, 2018 7:35 am
Adiddas11 wrote:I put a isuzu c223T in to my dads s10
I initially overlooked that it's a turbo, because that's not typical for an S10. It's quite possible that the turbo is leaving oil into the intake. Diesels tend to "run away" when oil gets into the intake.
Duck
Postby Duck » Fri Jun 01, 2018 8:20 pm
if someone has turned the smoke screw up too much, it will try to run away.
90 Dakota with C223
Adiddas11
Postby Adiddas11 » Tue Aug 14, 2018 4:29 pm
I changed the turbo with another one I have, and the problem is still the same. The throttle cable moves freely and does not get stuck
Postby FiatSpider2 » Wed Aug 15, 2018 7:35 am
Adiddas11 wrote:I changed the turbo with another one I have, and the problem is still the same. The throttle cable moves freely and does not get stuck
Was the intake plumbing coated inside with oil? If not then there was likely little need to change out the turbo to check for that. The valve cover vent flapper is another thing to check for a runaway condition as is for a plugged oil return line from the turbo.
If it does turn off by the key switch that would indicate your problem is more likely with the IP. If this was a gas to diesel conversion it could also possibly be from leaving the high pressure 60+ PSI fuel injection pump from the gasoline engine in the S10.
Adiddas11
Postby Adiddas11 » Wed Aug 15, 2018 4:28 pm
The s10 is factory diesel, how can I test or find out its the IP
